[mapserver] Java VM Crashes using the Mapscript API
Rick Innis
rick at INNIS.CA
Thu Jul 28 15:07:59 EDT 2005
Im revisiting this somewhat old thread to contribute a few insights
I've found while dealing with the same issue, in the hope it saves
someone else time and effort in the future. The thread "Mapscript
API: for object manipulation, not object creation?" , from earlier
this year, also has some info on this topic.
>> Christian reported a crash in layerObj.delete() which I
>> also detected.
>> I think I understood the following:
>> Let's say, we have an initialized mapObj mO;
>> layerObj lO = new layerObj(mO);
>> // Say lO is the 5th layer now.
>> // Now lO.swigCMemOwn == true and
>> // lO.swigCPtr points onto the mO.swigCPtr->layers[4]
>> // now the mapObj is deleted but the Java-layerObj continues to live.
>> // the C-layer-Object mO.swigCPtr->layers[4] will deleted and
>> freed also!
>> mO.delete()
>> // From now on O.swigCPtr points into invalid piece of C-memory.
I also encountered this a few months back but didn't have time to
write it up so coherently. One workaround I was given by Sean was to
use insertLayer() to add the layer, which makes a copy, allowing the
allocated Java object to be disposed of cleanly. This also requires
making and inserting styleObj and classObj instances:
// initially, layer not associated with any map
layerObj myLayer = new layerObj(null);
// initialise layer
classObj myClass = new classObj(null);
styleObj myStyle = new styleObj(null);
// initialize style, then insert into class
myClass.insertStyle(styleObj, -1);
// insert class into layer
myLayer.insertClass(myClass, -1);
// insert layer into map - makes copy!
int ret = map.insertLayer(annos, -1);
// get reference to inserted copy
myLayer = map.getLayer(i);
However, when I started labelling my dynamic layers I found that my
labels ended up with a black background. The workaround I found was
to define an empty layer in my map, including empty style info, and
use cloneLayer() to make copies as needed.
The layer definition looks like this:
# Blank generic annotation layer
LAYER
NAME user_layer
STATUS OFF
TYPE POINT
CLASS
STYLE
COLOR 255 255 255
END
LABEL
COLOR 255 255 255
END
END
END
To use it, I grab the layer from the map, clone it, initialize it,
and insert the clone into the map:
layerObj myLayer = map.getLayerByName
("blank_layer").cloneLayer();
// initialise...
The layer's type can be changed on the fly, so one definition
suffices for all layers.
--Rick.
