mapserver tif projections
Douglass Davis
douglass_davis at EARTHLINK.NET
Thu Jul 28 19:08:41 EDT 2005
Ethan Alpert wrote:
> You should be using the units of the laea projection rather than
> decimal degrees to set the EXTENT.
> It's very difficult to know from a lat/long box what the output of the
> projection will be. It's best to use the units of the projected
> coordinate system.
> -e
Thanks. That worked.... For all the other newbies, and since this was
so confusing to me, I thought I would post the solution for people to
google later.
My previous extent was in lat/lon
EXTENT -85 32 -75 3
Since I just wanted the North Carolina area, so I used the cs2cs
conversion program to convert from Lat Lon to Lambert Azimuthal Equal
Area Projection coordinates.
C:\mapserver\data>cs2cs +proj=latlong +datum=WGS84 +to +proj=laea
+ellps=clrk66
+lat_0=45 +lon_0=-100
-85 32 <---type lower left coords here
1417368.72 -1316195.76 0.000
-75 38 <--- type upper right coords here
2159115.16 -450114.08 0.000
New extent is
EXTENT 1417368.72 -1316195.76 2159115.16 -450114.08
# Projection (global, in Map object)
PROJECTION
# Projection parameters can be defined in two ways...
# This is the traditional Proj.4 definition of Lambert Azimuthal
Equal-Area
# projection for the Continental U.S.
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
END
# My tif layer:
LAYER
NAME elevation
DATA "elevation/05539624.tif"
TYPE RASTER
STATUS ON
END
# Another layer with the a projection:
LAYER
NAME counties
DATA "counties/co37_d00"
TYPE POLYGON
STATUS ON
CLASSITEM "STATE"
CLASS
NAME counties
EXPRESSION "37"
STYLE
COLOR -1 -1 -1
OUTLINECOLOR 5 5 5
END
END
PROJECTION
"init=epsg:4326"
END
END
PHP Stuff:
http://www.douglassdavis.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050728/3f4420d6/attachment.html
