[mapserver] Java VM Crashes using the Mapscript API
Sean Gillies
sgillies at FRII.COM
Thu Jul 28 17:02:06 EDT 2005
On Jul 28, 2005, at 2:43 PM, Rick Innis wrote:
> On Jul 28, 2005, at 16:15, Sean Gillies wrote:
>> All the MapServer classes exist primarily to support the CGI
>> mapserv program, and therefore are complete. An new instance of
>> classObj, for example, already contains a labelObj attribute named
>> "label". To set a class's label color, you should do this
>> class.label.color.setRGB(red, green, blue)
> So to get rid of the black background, would it be legitimate to do
> this?
> class.getLabel().getBackgroundcolor().setRGB(-1, -1, -1);
> class.getLabel().getBackgroundshadowcolor().setRGB(-1, -1, -1);
> --Rick.
Rick,
I don't think that is necessary for a classObj's natural label member.
Try this
classObj co = new classObj(null);
co.getLabel().getBackgroundcolor().getRed() .... should be -1
On the other hand, if you do this
labelObj lo = new labelObj();
lo.getBackgroundcolor().getRed() .... will be 0
The second example is improper usage, the label's colors never get
properly initialized in this case. Users ought to be better protected
from these sharp edges of mapscript, but alas.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
