landview DHTML interface: adding elements
Dylan Beaudette
dylan at IICI.NO-IP.ORG
Fri Jul 29 14:44:44 EDT 2005
Greetings,
I am interested in building on top of the excellent landview DHTML interface
for mapserver. Specifically, I would like to add a bit of text just below the
scale bars, with a message about the map scale. I would like this message to
be updated with every interaction with the map. My attempts thus far are not
updated after map interaction.
So far i have created a function that creates a custom message based on the
scale of the map like this:
function display_current_message()
var current_scale = ms.getscale();
var message = "";
if(current_scale > 50001 )
message = "You are currently working with scale A.";
else
message = "You are currently working with scale B.";
return message;
<div id="message"
(put message here via JS)
</div>
Is there a general method of updating the contents of the landview DHTML page
that i can use to update my custom bit of text?
thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
