Problem configuring WFS-SERVER on oraclespatial layers
Fernando Simon
fsimon at UNIVALI.BR
Wed Jun 8 07:44:07 EDT 2005
Hi Ludovic and Bart,
About the problem with WFS (I'm not a specialist in WFS) did you
check all the metadata parameters? (upper case/lower case)
You can check all the messages that Mapserver request to Oracle
server using a debug flag (inf mapfile and configure for mapserver). You
need to specify a "--enable-debug" for configure and DEBUG parameter for
layer and MAP in you mapfile. Using this way all of actions and SQL
appear in apache error log.
I recommend to pass the UNIQUE parameter in your DATA definition. In
UNIQUE parameter you define the column that store the unique values
(usually primary key) for your table. This is necessary for retrieve the
correct data from database. You can specify like this: (null SRID is
default when you don't specify)
DATA "GEOM FROM BATIMENT USING UNIQUE <column>" example
DATA "GEOM FROM BATIMENT USING UNIQUE BATIMENT_ID"
Can you change the data and test the result for this case?
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
ludovic gnemmi wrote:
>Bart,
>You were right with MWS...I hat to add "wms_extent" on
>each layer to make WMS works with MS 4.6...I can now
>view all my layers with wms:)
>But still can't see oracle layers with WFS.
>I don't think communication failing with oracle...I
>see oracle is processing when sending WFS getfeature
>request. And i still can see oracle layers with
>Mapserver in normal use.
>Thanks.
>Ludovic
>--- Bart van den Eijnden <BEN at SYNCERA-ITSOLUTIONS.NL>
>a écrit :
>>It seems that all aspects which communicate with
>>Oracle fail. I had a look at your original post and
>>the GML created only contained the wfs_extent values
>>you put in the MAP file. So probably all
>>communication with Oracle is failing.
>>The WMS capabilities now use a function to calculate
>>the boundingbox. If you use a wms_extent metadata it
>>will probably be complete.
>>Are you able to get normal maps?
>>I hope Fernando Simon can help you further.
>>Best regards,
>>Bart
>>Syncera IT Solutions
>>Postbus 270
>>2600 AG DELFT
>>tel.nr.: 015-7512436
>>email: BEN at Syncera-ITSolutions.nl
>>>>>ludovic gnemmi <l_gnemmi at YAHOO.FR> 06/08/05
>>08:58am >>>
>>Hi,
>>I'm now testing with mapserver 4.6 beta3. I still
>>receive nothing with getfeature request on
>>oraclespatial layers (i can see that oracle is
>>processing the requests).
>>And i'm now receiving an uncomplete xml file when
>>testing wms capabilities (stoped on <Layer
>>queryable=).
>>On more thing, i see a new message in my apache
>>error
>>log : "In msCleanupOnSignal". ???
>>Ludovic
>><BEN at Syncera-ITSolutions.NL>
>>a écrit :
>>>Okay, my information was 4.6 specific. I was
>>>assuming you were using that version.
>>>Could you try the latest 4.6 beta? There have also
>>>been a lot of improvements made by Fernando in
>>>maporaclespatial.c.
>>>Best regards,
>>>Bart
>>>Postbus 270
>>>2600 AG DELFT
>>>>>>ludovic gnemmi <l_gnemmi at YAHOO.FR> 06/07/05
>>>09:22am >>>
>>>Hi,
>>>Thanks for your answer Bart but it still doesn't
>>>work...I'm trying with mapserver 4.4.2...Is
>>>gml_include_tems include in mapserver 4.4.2? Or
>>i'll
>>>have to upgrade to 4.4.6?
>>>Ludovic
>>>--- Bart van den Eijnden <bartvde at XS4ALL.NL> a
>>écrit
>>>>Hi,
>>>>use:
>>>>gml_include_items "all"
>>>>in the METADATA section of your LAYER.
>>>>Best regards,
>>>>Bart
>>>>On Mon, 06 Jun 2005 18:32:03 +0200, ludovic
>>gnemmi
>>>>wrote:
>>>>>Hi all,
>>>>>I have a problem configuring WFS-SERVER with
>>>>>oraclespatial (Nativ support)
>>>layers...Everything
>>>>is
>>>>>ok when configuring WMS-SERVER on these layers
>>>>but i
>>>>>still receive an incomplete XML result when i
>>>try
>>>>a
>>>>>getfeature request on my WFS oraclespatial
>>>layers
>>>>>(without errors). getcapabilitie request is
>>OK.
>>>>>getfeature requests are OK on shapefiles.
>>>>>Here is my mapfile:
>>>>>MAP
>>>>> NAME "my_wfs"
>>>>> EXTENT 868470 83215 965015 165840
>>>>> SIZE 400 300
>>>>> IMAGETYPE PNG
>>>>> IMAGECOLOR 255 255 255
>>>>> STATUS ON
>>>>> UNITS METERS
>>>>> FONTSET "path to font"
>>>>> SYMBOLSET "path to symbol"
>>>>> SHAPEPATH "path to shape"
>>>>>WEB
>>>>> IMAGEPATH "path to images"
>>>>> IMAGEURL "/ms_tmp/"
>>>>>METADATA
>>>>> "wfs_title" "my_wfs"
>>>>> "wfs_onlineresource"
>>>"http://localhost/cgi-bin/mapserv?map=my_wfs.map&"
>>>>> "wfs_srs" "EPSG:27582"
>>>>>END
>>>>>END
>>>>>#oracle spatial layer
>>>>>LAYER
>>>>>NAME "bati"
>>>>>TYPE POLYGON
>>>>>CONNECTIONTYPE oraclespatial
>>>>>CONNECTION "usr/pass at DB"
>>>>>DATA "GEOM FROM BATIMENT USING SRID NULL"
>>>>>DUMP TRUE
>>>>>STATUS DEFAULT
>>>>>DEBUG ON
>>>>>PROJECTION
>>>>>"init=epsg:27582"
>>>>>END
>>>>>METADATA
>>>>>"wfs_title" "bati"
>>>>>"wfs_extent" "868470 83215 965015 165840"
>>>>>END
>>>>>CLASSITEM "BAT_CODE"
>>>>>CLASS
>>>>> EXPRESSION "01"
>>>>> COLOR 152 152 152
>>>>> OUTLINECOLOR 0 0 0
>>>>>END
>>>>>CLASS
>>>>> EXPRESSION "02"
>>>>> COLOR 202 202 202
>>>>> OUTLINECOLOR 0 0 0
>>>>>END
>>>>>END
>>>>>END
>>>>>here the result of a getfeature request on
>>this
>>>>layer:
>>>>> <wfs:FeatureCollection
>>>>>xsi:schemaLocation="http://www.opengis.net/wfs
>http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
>>http://www.ttt.org/myns
>http://localhost/cgi-bin/mapserv?map=my_wfs.map&SERVICE=WFS&VERSION=1...0.0&REQUEST=DescribeFeatureType&TYPENAME=bati">
>>>>> <gml:boundedBy>
>>>>> <gml:Box srsName="EPSG:27582">
>>>>> <gml:coordinates>
>>>>>874619.370000,112072.490000
>>>>>875774.930000,113685.950000
>>>>></gml:coordinates>
>>>>></gml:Box>
>>>>></gml:boundedBy>
>>>>></wfs:FeatureCollection>
>>>>>Has anybody got an idea?
>>>>>Thanks a lot.
>>>>>Ludovic
>_____________________________________________________________________________
>>>>>Découvrez le nouveau Yahoo! Mail : 1 Go
>>d'espace
>>>>de stockage pour vos
>>>>>mails, photos et vidéos !
>>>>>Créez votre Yahoo! Mail sur
>>>>http://fr.mail.yahoo.com
>>>>Using Opera's revolutionary e-mail client:
>>>>http://www.opera.com/mail/
>>>Découvrez le nouveau Yahoo! Mail : 1 Go d'espace
>>de
>>>stockage pour vos mails, photos et vidéos !
>>Découvrez le nouveau Yahoo! Mail : 1 Go d'espace de
>>Créez votre Yahoo! Mail sur http://fr.mail.yahoo.com
>Découvrez le nouveau Yahoo! Mail : 1 Go d'espace de stockage pour vos mails, photos et vidéos !
