Perl Mapscript 4.4 Issues
Aaron Craig
mercutio at POBOX.COM
Mon Jun 20 02:16:23 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
At the risk of pointing out the obvious -- you did re-install
mapscript.pm when you upgraded MS? That doesn't happen automatically.
Rob Ellis wrote:
| On Mon, 25 Apr 2005 08:18:22 -0400, Lowell Filak <lfilak at MEDINACO.ORG>
| wrote:
|>The following message was sent by Stephen Woodbridge
|><woodbri at SWOODBRIDGE.COM> on Sun, 24 Apr 2005 23:23:26 -0400.
|>>Hi all,
|>>I'm looking at the SWIGMapScript doc and have run into a few problems.
|>>$mapObj->setExtent($minx, $miny, $maxx, $maxy);
|>>and throws an error:
|>>Can't locate auto/mapscript/mapObj/setExtent.al in @INC (@INC contains:
|>>/etc/perl /usr/local/lib/perl/5.8.4 /usr/local/share/perl/5.8.4
|>>/usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8
|>>/usr/local/lib/site_perl /usr/local/lib/perl/5.8.0
|>>/usr/local/share/perl/5.8.0 .) at index.cgi line 255
|>>Also looking at the document it looks like there is an
|>>$layerObj->setExtent(...) which doesn't seem to be correct.
|>>The classObj doc says it "Provides access to all class parameters
|>>(color, symbol, label, & etc...)." but there is no doc to indicate there
|>>is a symbol property, nor is there any of doc/properties for color,
|>>overlaycolor, size, overlaysize. I think these were moved to styleObjs
|>>so it might be appropriate to comment on that.
|>Steve,
|>What version are you using?
|>I just double checked and there is most certainly a 'setExtent' for the
|>mapObj in the mapscript.pm.
|>You are correct on the classObj not. It is an old note that needs to be
|>deleted. Sorry for the confusion.
|>Lowell
| Sorry to take you guys back to something that you've allready sorted out,
| but I'm a little confused. I've upgraded to MS4.4.2 but am getting the
| following message when trying to use Perl Mapscript, and from the previous
| messages it looks as though I might just need to alter mapscript.pm:
| Can't locate auto/mapscript/classObj/swig_styles.al
| Am I right in interpreting the previous emails when I assume that I
need to
| remove refernces to classObj in mapscript.pm, or am I way off?
| Thanks
| Rob
Aaron Craig
mercutio at pobox.com
Get Firefox!
http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
Sweet are the uses of adversity.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.3-nr1 (Windows 2000)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCtl83oyEQRcU83p4RAl4OAKCPXzvjvIWdebFtDKd1A0XVFAsTGwCfa8Mo
wCX9x6p0oMIuX4XsPuEJgYI=
=WRP5
-----END PGP SIGNATURE-----
