Perl Mapscript 4.4 Issues
    Ellis Robin (Bundaberg)
    Robin.Ellis at NRM.QLD.GOV.AU
    Sun Jun 19 23:33:58 PDT 2005
Yes Aaron, thanks for that. I have copied across the 'new' mapscript.pm and restarted Apache (a couple of times). That's not to say that I won't be really, really happy if my solution is as simple as your porposal!
Rob
-----Original Message-----
Sent: Monday, 20 June 2005 4:16 PM
To: Ellis Robin (Bundaberg)
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Perl Mapscript 4.4 Issues
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
At the risk of pointing out the obvious -- you did re-install
mapscript.pm when you upgraded MS?  That doesn't happen automatically.
Rob Ellis wrote:
| On Mon, 25 Apr 2005 08:18:22 -0400, Lowell Filak <lfilak at MEDINACO.ORG>
| wrote:
|>The following message was sent by Stephen Woodbridge
|><woodbri at SWOODBRIDGE.COM> on Sun, 24 Apr 2005 23:23:26 -0400.
|>>Hi all,
|>>I'm looking at the SWIGMapScript doc and have run into a few problems.
|>>$mapObj->setExtent($minx, $miny, $maxx, $maxy);
|>>and throws an error:
|>>Can't locate auto/mapscript/mapObj/setExtent.al in @INC (@INC contains:
|>>/etc/perl /usr/local/lib/perl/5.8.4 /usr/local/share/perl/5.8.4
|>>/usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8
|>>/usr/local/lib/site_perl /usr/local/lib/perl/5.8.0
|>>/usr/local/share/perl/5.8.0 .) at index.cgi line 255
|>>Also looking at the document it looks like there is an
|>>$layerObj->setExtent(...) which doesn't seem to be correct.
|>>The classObj doc says it "Provides access to all class parameters
|>>(color, symbol, label, & etc...)." but there is no doc to indicate there
|>>is a symbol property, nor is there any of doc/properties for color,
|>>overlaycolor, size, overlaysize. I think these were moved to styleObjs
|>>so it might be appropriate to comment on that.
|>Steve,
|>What version are you using?
|>I just double checked and there is most certainly a 'setExtent' for the
|>mapObj in the mapscript.pm.
|>You are correct on the classObj not. It is an old note that needs to be
|>deleted. Sorry for the confusion.
|>Lowell
| Sorry to take you guys back to something that you've allready sorted out,
| but I'm a little confused. I've upgraded to MS4.4.2 but am getting the
| following message when trying to use Perl Mapscript, and from the previous
| messages it looks as though I might just need to alter mapscript.pm:
| Can't locate auto/mapscript/classObj/swig_styles.al
| Am I right in interpreting the previous emails when I assume that I
need to
| remove refernces to classObj in mapscript.pm, or am I way off?
| Thanks
| Rob
Aaron Craig
mercutio at pobox.com
Get Firefox!
http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
Sweet are the uses of adversity.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.3-nr1 (Windows 2000)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCtl83oyEQRcU83p4RAl4OAKCPXzvjvIWdebFtDKd1A0XVFAsTGwCfa8Mo
wCX9x6p0oMIuX4XsPuEJgYI=
=WRP5
-----END PGP SIGNATURE-----
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
More information about the MapServer-users
