WMS time support with a database
uli mueller [geOps]
uli.mueller at GMX.CH
Tue Mar 1 08:48:31 EST 2005
Marco
There is the documentation at
http://mapserver.gis.umn.edu/doc44/wms-time-support-howto.html
For PostGIS I used the following settings at layer level:
LAYER
METADATA
...other metadata ...
"wms_timeextent" "1994-12-31/2004-12-31"
"wms_timedefault" "1994-12-31/2004-12-31"
"wms_timeitem" "MyDateField"
END
DATA "the_geom from MyView USING UNIQUE oid USING SRID=4326"
END
"MyView" is a PostgreSQL view containing the geometry and a field named
MyDateField of type "timestamp with time zone". However any other date
data type should work as well.
I query this WMS through
http://myhost/my.wms?VERSION=1.1.1&REQUEST=GetMap&LAYERS=MyLayer&TIME=2002/2004....
!?! Seems as if with TIME support any setting in the layer's FILTER
parameter are overridden. I had posted this yesterday (Message "WMS TIME
conflict with FILTER") and am still hoping to get an answer on this.
Uli
Marco Marsella wrote:
> Hi list,
> I am trying to figure out how to configure Mapserver to provide WMS
> server support for time dimensions using a database.
> I have examples that use a shapefile to map time request values to the
> actual filename, but I cannot find any description of how to do the
> same using a database table.
> Anybody willing to shed some light ?
> TIA
> Marco
geOps GeoInformatics
D-79100 Freiburg
