get part of very large raster
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Mar 2 04:16:39 EST 2005
Hi Ivan,
you can use GDAL to do this:
gdal.maptools.org
More specifically, the gdal_translate utility can clip:
-srcwin xoff yoff xsize ysize:
Selects a subwindow from the source image for copying based on pixel/line
location.
-projwin ulx uly lrx lry:
Selects a subwindow from the source image for copying (like -srcwin) but
with the corners given in georeferenced coordinates.
Best regards,
Bart
> Hi, everybody
> I have little problem,
> I have very large raster over 100M, and I have to programming small
> program, that on input get Xmin, Xmax, Ymin, Ymax and return small wedge
> of this large raster.
> My first test was using GD library but problem is that this library load
> whole raster into memory and its mean, that its take very long time.
> I know (I am developing something on mapserver), that mapserver is doing
> this and very fast and my question is, which library mapserver is using ,
> or which part of code is processing this ?
> Thanks very much for your reply
> ivan mjartan
