A confused Network Admin
Lisi, Christine
lisi at MYDELRAYBEACH.COM
Wed Mar 2 11:51:14 EST 2005
The consultant told me to have both so I don't understand. MapScript is
a MapServer module, no?
Christine Lisi
Application Specialist
Management Information Systems * City of Delray Beach * 100 NW First
Avenue, Delray Beach, FL 33444
Phone, 561-243-7142 * Fax, 561-243-7166 * eMail, Lisi at MyDelrayBeach.com
-----Original Message-----
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Wednesday, March 02, 2005 11:44 AM
To: Lisi, Christine
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] A confused Network Admin
Christine,
you don't (normally) need both MapServer and MapScript ... you would use
one or the other. And the versions wouldn't have to match (except
perhaps for dependencies).
MapScript is completely self-contained ...
Paul
Lisi, Christine wrote:
> OK, Paul's script now works and returns no errors - also sees
MapScript.
> The way I accomplished this was that I downloaded PHP MapScript
version
> 4.5 for PHP 5.0.3 (thank you Yewondwossen!). It says it's compatible
> with MapServer 4.5, but I can't find that version on the MapServer
site.
> The latest listed is 4.4.1. Why oh why does this all have to be so
> complicated?! Does anyone know where I can download MapServer 4.5?
> My other concern is that many of the .dll files in this MapScript 4.5
> version are older than those in MapServer. I did replace the
gdal12.dll
> in MapServer with the version 1.2.5 from MapScript 4.5 because it
states
> in the README.txt that MapScript requires this version. I hope this
> doesn't mess things up in the long run.
> Is anyone else as frustrated as I am?
> Christine Lisi
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
On
> Behalf Of Paul Spencer
> Sent: Wednesday, March 02, 2005 9:15 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> slight clarification, the php module name is case sensitive and for
> mapscript it is actually "MapScript".
> For the record, my test script for testing MapScript extension is a
> little simpler :)
> <?php
> if (!extension_loaded('MapScript'))
> dl('php_mapscript_44.'.PHP_SHLIB_SUFFIX);
> phpinfo();
> Also, for most purposes, it is more convenient to make a copy of
> php_mapscript_44.dll and name it php_mapscript.dll, then your scripts
> can all reference php_mapscript.dll as the most recent version. When
> 4.6 comes out, you can test your apps then upgrade everything by
making
> php_mapscript.dll a copy of php_mapscript_46.dll
> Cheers
> Paul
> William Bronsema wrote:
>>Also note that the extension_loaded check is not the extension_name
>>(i.e. php_mapscript_44) rather it is the module name itself. In this
>>case it is "mapscript". Your code should be:
>>if(!extension_loaded('mapscript'))
>>HTH,
>>Bill
>>________________________________________________
>>William A. Bronsema, C.E.T.
>>Applications and Software Development,
>>DM Solutions Group Inc.
>>*From:* UMN MapServer Users List
>>*On Behalf Of *Jeff Portwine
>>*Sent:* March 2, 2005 8:19 AM
>>*To:* MAPSERVER-USERS at LISTS.UMN.EDU
>>*Subject:* Re: [UMN_MAPSERVER-USERS] A confused Network Admin
>>Make sure that you have the <?PHP line in front of everything and
> that
>>the script is ended with ?>.
>>I think in the original example he just had <? which should be ok,
> but
>>I like to use <?PHP myself. It looks like your script omitted the
>>so it wasn't being recognized as a php script and was just reading the
>>script as though it were html and outputting the text to your browser.
>>Hope this helps,
>>Jeff
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
