SIMPLE (I HOPE) Problems with Tiff images
Ben
bmad0463 at MAIL.USYD.EDU.AU
Wed Mar 2 21:36:26 EST 2005
I am having a more simple problem with Rasters, I was wondering if you could help.
I am using MServ 4.4.1 on OS X, and working through the tutorial, (all going well) but
when I get to 1.5, where a raster background map is introduced, I stopped getting
images.
If I comment out the RASTER details, I get the rest of the map, so I suspect my links
are otherwise OK.
the mapfile as far as the offending section is :
MAP
IMAGETYPE PNG24
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "data"
FONTSET "fonts/fonts.list"
SYMBOLSET "symbols/symbols35.sym"
PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
"init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS OFF
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION 'land'
COLOR 232 232 232
END
END # States polygon layer ends here
#LAYER # MODIS raster layer begins here
# NAME modis
# DATA "raster/mod09a12003161_ugl_ll_8bit.tif"
# STATUS DEFAULT
# TYPE RASTER
# PROCESSING "BANDS=1,2,3"
# OFFSITE 71 74 65
# PROJECTION
# "init=epsg:4326"
# END
#END # MODIS raster layer ends here
I commented it out to check it works without the raster layer which it does. I am
assuming that the second data reference is relation to the original data directory.
It calls for a tiff image, which according to phpinfo() should be available (I am using
the CGI version, but both compiled at the same time.)
MapServer Version
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=
WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=
WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=SHAPEFILE
GDAL doesn't seem to have compiled, but I gather it should still work OK, have I
missed something?
cheers
Ben
