SIMPLE (I HOPE) Problems with Tiff images
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Mar 2 22:16:57 EST 2005
On Wed, 2 Mar 2005 20:36:26 -0600, Ben <bmad0463 at mail.usyd.edu.au> wrote:
> It calls for a tiff image, which according to phpinfo() should be available (I am using
> the CGI version, but both compiled at the same time.)
> MapServer Version
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=
> WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=
> WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> INPUT=SHAPEFILE
> GDAL doesn't seem to have compiled, but I gather it should still work OK, have I
> missed something?
Ben,
It looks like you have a 3 band (RGB) image. That is not supported by
the built-in TIFF code. You will need GDAL built in for this.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
