finding shortest path between two points
Schuyler Erle
schuyler at NOCAT.NET
Fri Mar 4 12:18:06 EST 2005
One note: You want to be careful doing this with TIGER/Line data,
because it doesn't include street-directionality, and so you can
generate driving routes that are illegal or even dangerous.
SDE
* On 4-Mar-2005 at 9:15AM PST, Stephen Woodbridge said:
> That would be Dijkstra's algorithm, see:
> http://ciips.ee.uwa.edu.au/~morris/Year2/PLDS210/dijkstra.html
> There are lots of examples of code on the net for this. I have
> implemented a prototype, but it is not opensource. You can play with the
> demo I have at
> http://imaptools.com/demos1/?tab=2
> -Steve
> Solomon wrote:
> >hi guys
> > thank u for ur support. now does anyone has a clue on how to implement
> >pathfinding. the user specifies source and destination, and code finds the
> >shortest distance between source and destination (like what is implemeted
> >in yahoo maps) and then the path is highlighted. am using mapserver
> >4.4.2,phpmapscript,oracle 9i spatial all running on linux. any help in the
> >right direction will be appreciated.
