Figure out the XY position on the resulting map of a point
Paul Spencer
pspencer at DMSOLUTIONS.CA
Sun Mar 6 17:10:03 EST 2005
Hi James.
Assuming your output projection is not lat/lon, you can create a point
object and reproject it into the map's projection and do the same
calculation. Here's some (untested) code that should work:
$oProjIn = ms_newProjectionObj("init=epsg:4326");
$oProjOut = ms_newProjectionObj($oMap->getProjection());
$oPoint = ms_newPointObj();
$oPoint->setXY( $lon, $lat );
$oPoint->project( $oProjIn, $oProjOut );
$px = Geo2Pix( $oPoint->x, 0, $oMap->width
$oMap->extent->minx, $oMap->extent->maxx, false );
$py = Geo2Pix( $oPoint->y, 0, $oMap->height
$oMap->extent->miny, $oMap->extent->maxy, true );
* convert a geocoded position to pixel coord
* @param nGeoPos double Geocoded position
* @param dfPixMin double minimum map pixel value
* @param dfPixMax double maximum map pixel value
* @param dfGeoMin double minimum map geocoded value
* @param dfGeoMax double maximum map geocoded value
* @param nInverseGeo integer optional flag to inverse , set to 1 for
* Y pixel coordinates where UL > LR
* @return double geocoded position
function Geo2Pix ($nGeoPos, $dfPixMin, $dfPixMax, $dfGeoMin,
$dfGeoMax, $nInverseGeo = "")
// calculate the geocoded & pixel width
$dfWidthGeo = abs($dfGeoMax - $dfGeoMin);
$dfWidthPix = abs($dfPixMax - $dfPixMin);
// get ratio
if ( $dfWidthGeo <= 0 )
return 0;
$dfGeoToPix = $dfWidthPix / $dfWidthGeo;
// get difference
if (!$nInverseGeo)
$dfDeltaGeo = $nGeoPos - $dfGeoMin;
else
$dfDeltaGeo = $dfGeoMax - $nGeoPos;
// calculate
$dfDeltaPix = $dfDeltaGeo * $dfGeoToPix;
$dfPosPix = $dfPixMin + $dfDeltaPix;
// return value
return round ($dfPosPix);
// end pixel_to_geo function
Cheers,
Paul
James wrote:
> Hello,
> Using mapscript, is there a way to figure out what the resultant XY position
> of a point object will be on the output image? As an example, using a
> simple lat/lon projection, knowing the lat/lon position of the point, the
> dimensions of the image and the extent, simple algebra leads me to the XY
> position of said point.
> However, when using a different projection this is not possible as each
> pixel no longer represents the same amount of lat/lon distance. I can
> project my lat/lon point to the new projection, but is there any way to
> extract the XY coordinates?
> Obviously Mapserver must do this to actually place the point on the
> resulting image, but I haven't been able to figure out how to get at that
> information. Any suggestions are greatly appreciated.
> Thank you,
> James
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
