Figure out the XY position on the resulting map of a point
James Martin
martin426 at YAHOO.COM
Mon Mar 7 12:26:19 EST 2005
Duh.. It works exactly as you say, for some reason it just didn't
seem logical to me so I never tried it and of course dove into looking for a
much more complex solution. Thanks for setting me straight Paul!
For any pythoners out there I've included a translation (minus the
comments--they're essentially the same):
def Geo2Pix (nGeoPos, dfPixMin, dfPixMax, dfGeoMin, dfGeoMax, nInverseGeo =
False):
dfWidthGeo = abs(dfGeoMax - dfGeoMin)
dfWidthPix = abs(dfPixMax - dfPixMin)
if dfWidthGeo > 0:
dfGeoToPix = dfWidthPix / dfWidthGeo
if nInverseGeo:
dfDeltaGeo = dfGeoMax - nGeoPos
else:
dfDeltaGeo = nGeoPos - dfGeoMin
dfDeltaPix = dfDeltaGeo * dfGeoToPix
dfPosPix = dfPixMin + dfDeltaPix
return round(dfPosPix)
return False # dfWidthGeo is <= 0
-James
On Sun, 6 Mar 2005 17:10:03 -0500, Paul Spencer <pspencer at DMSOLUTIONS.CA> wrote:
>Hi James.
>Assuming your output projection is not lat/lon, you can create a point
>object and reproject it into the map's projection and do the same
>calculation. Here's some (untested) code that should work:
>$oProjIn = ms_newProjectionObj("init=epsg:4326");
>$oProjOut = ms_newProjectionObj($oMap->getProjection());
>$oPoint = ms_newPointObj();
>$oPoint->setXY( $lon, $lat );
>$oPoint->project( $oProjIn, $oProjOut );
>$px = Geo2Pix( $oPoint->x, 0, $oMap->width
> $oMap->extent->minx, $oMap->extent->maxx, false );
>$py = Geo2Pix( $oPoint->y, 0, $oMap->height
> $oMap->extent->miny, $oMap->extent->maxy, true );
> * convert a geocoded position to pixel coord
> * @param nGeoPos double Geocoded position
> * @param dfPixMin double minimum map pixel value
> * @param dfPixMax double maximum map pixel value
> * @param dfGeoMin double minimum map geocoded value
> * @param dfGeoMax double maximum map geocoded value
> * @param nInverseGeo integer optional flag to inverse , set to 1 for
> * Y pixel coordinates where UL > LR
> * @return double geocoded position
>function Geo2Pix ($nGeoPos, $dfPixMin, $dfPixMax, $dfGeoMin,
> $dfGeoMax, $nInverseGeo = "")
> // calculate the geocoded & pixel width
> $dfWidthGeo = abs($dfGeoMax - $dfGeoMin);
> $dfWidthPix = abs($dfPixMax - $dfPixMin);
> // get ratio
> if ( $dfWidthGeo <= 0 )
> return 0;
> $dfGeoToPix = $dfWidthPix / $dfWidthGeo;
> // get difference
> if (!$nInverseGeo)
> $dfDeltaGeo = $nGeoPos - $dfGeoMin;
> else
> $dfDeltaGeo = $dfGeoMax - $nGeoPos;
> // calculate
> $dfDeltaPix = $dfDeltaGeo * $dfGeoToPix;
> $dfPosPix = $dfPixMin + $dfDeltaPix;
> // return value
> return round ($dfPosPix);
> // end pixel_to_geo function
>Cheers,
>Paul
>James wrote:
>> Hello,
>> Using mapscript, is there a way to figure out what the resultant XY position
>> of a point object will be on the output image? As an example, using a
>> simple lat/lon projection, knowing the lat/lon position of the point, the
>> dimensions of the image and the extent, simple algebra leads me to the XY
>> position of said point.
>> However, when using a different projection this is not possible as each
>> pixel no longer represents the same amount of lat/lon distance. I can
>> project my lat/lon point to the new projection, but is there any way to
>> extract the XY coordinates?
>> Obviously Mapserver must do this to actually place the point on the
>> resulting image, but I haven't been able to figure out how to get at that
>> information. Any suggestions are greatly appreciated.
>> Thank you,
>> James
>|Paul Spencer pspencer at dmsolutions.ca |
>|Applications & Software Development |
>|DM Solutions Group Inc http://www.dmsolutions.ca/|
