Python Mapscript QueryByPoint
Eric Bridger
eric at GOMOOS.ORG
Tue Mar 8 06:06:51 PST 2005
On Tue, 2005-03-08 at 07:49, Jon Saints wrote:
> I am having trouble querying a flat shapefile using
> python mapscript with the queryByPoint function.
> My getResults always equals None. I believe my trouble
> has something to do with: (from the swig
> documentation) "A query will not set results for a
> layer with a NULL 'template' attribute."
> I have tried using both map and pixel coords for the
> point object. Both point objects, I am sure intersect
> a feature of layer 0 on my map.
> I receive the error:
> "'NoneType' object has no attribute 'numresults'"
> My code:
> #Map coords
> #click = pointObj()
> #click.x = 77.01
> #click.y = 38.89
> #pixel Coords
> click = pointObj()
> click.x = 300
> click.y = 200
> myMap.getLayer(0).queryByPoint( myMap, click,
> MS_SINGLE, 10.0 )
> results = myMap.getLayer(0).getResults()
> output = results.numresults
> excerpt from My mapfile:
> LAYER
> NAME dcdem2000
> TYPE POLYGON
> STATUS ON
> METADATA
> desc "Census Blocks"
> logo "test.jpg"
> END
> DATA "/home/jons/Data/DC/created/dcdem2000"
> CLASS
> NAME "Census Blocks 2000"
> COLOR 225 225 225
> OUTLINECOLOR 100 100 100
> END
> END
In your LAYER add TEMPLATE "ttt".
That will define a template and allow queries even though you don't use
it.
Eric
More information about the MapServer-users
