Odd mapserv CGI problem
Ken Lord
kenlord at GMAIL.COM
Wed Mar 9 17:10:07 EST 2005
Hi Avi,
If you are using IIS, make sure that your scripts folder has 'execute
permissions' set to 'scripts and executables'
Cheers,
Ken Lord
Vancouver BC
On Wed, 9 Mar 2005 15:27:33 -0600, Avi A Blackmore <sysadmin at satshot.com> wrote:
> I'm having a very peculiar problem with Mapserver 4.0.1. Given a valid
> mapfile, which points to valid index and shape files (for vector layers), the
> shp2img program returns the correct image.
> However, when I try to run the same query (same extents, map file, and the
> like) through the CGI mapserv program via a browser, the program returns...a
> copy of itself. As in, a copy of the ELF 32-bit binary executable.
> I have no idea whatsoever why it does this, especially since the mapfile is
> known to be correct (it's automatically generated by a Java webapp), and
> works for shp2img. Any ideas on where to start looking?
> Thanks,
> Avi Blackmore
> Agri ImaGIS Technologies
> System Administrator
