Errorlog/errormessages? (problem is drawReferenceMap)
Ragnvald Larsen
ragnvald at MINDLAND.COM
Thu Mar 10 03:46:24 EST 2005
I am having troubles with making a referencemap using this:
$referencemap=$map->drawReferenceMap();
The real map is already made - perfectly. So it is only when I try to make
a reference-map things go bad and the output aborts.
Trying to solve this myself I was looking for an error-log, but it simply
is not there. Where do I turn it on?
This is my Mapscript configuration:
MapServer Version MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
PHP MapScript Version ($Revision: 1.220.2.2 $ $Date: 2004/12/19 22:17:59
GD version: bundled (2.0.28 compatible)
Any suggestions?
Ragnvald Larsen
TAWIRI, Tanzania
