Errorlog/errormessages? (problem is drawReferenceMap)
Ragnvald Larsen
ragnvald at MINDLAND.COM
Thu Mar 10 04:37:55 EST 2005
Yes I think I am using a map object. The map is made by using a mapfile like
this:
$map_file="tanzania.map";
$map = ms_newMapObj($map_file);
This draws the map-object which I am successfully using later in my code
when I get the map image saved:
$image=$map->draw();
$image_url=$image->saveWebImage();
Then I print it to the screen:
<img src="<?php echo $image_url ?>"</img>
And work further on it to get a list of layers like this:
$nLayers=$map->numlayers;
for ($i=0;$i<$nLayers; $i++) {
$oLayer=$map->getlayer($i);
echo $oLayer->name."<br>";
It all really works smoothly until I try making a reference map by using
this line.
$image = $map->drawReferenceMap();
That's where it just stops. Actually no more code is fed to the browser
after this line. A complete halt...
Ragnvald
