LabelAngleItem question
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Mar 11 10:16:24 EST 2005
Seems like you should be able to add another column without impacting
the other applications or create a view with this new column, then add
something like a trigger or stored procedure the updates your new column
anytime the angle field is modified. This would make it all automagic
and the application writing the records would not need to know about the
extra column. I don't know all the details on how to do this or if it is
even possible, so I'll defer to the postgresql experts at this point :)
-Steve
Stéphane RIFF wrote:
> I want to show gps positions with orientation path.
> I use mapscript 4.2.5 and postgis as datasource.
> I don't think i can modify the datasource field because
> another application use the same data and i don't have access to those
> source...
> Thanks
> Eric Bridger wrote:
>> On Fri, 2005-03-11 at 03:21, Stéphane RIFF wrote:
>>> Can someone show me an example because
>>> i don't know how to do it.
>>> I can create dynamic layer but the problem
>>> is how to set orientation for each points, i don't think
>>> a class for each orientation is a good solution
>>> but i don't see anything else.
>> You are not providing enough details about what you are trying to do.
>> Where are your points? Shapefile, PostGIS, etc.
>> Are you using CGI Mapserver or Mapscript?
>> If I understand correctly the only issue is that your angles need to be
>> mulitplied by -1. The easiest way is to create a new column in your
>> datasource which is negative of you existing angles. And use the new
>> column as your LABELANGLEITEM.
