Newbie stucked - no maps at all.
Rodrigo Severo
rodrigo.lists at FABRICADEIDEIAS.COM
Sat Mar 12 10:16:48 EST 2005
I have, apparently, installed mapserver and php/mapscript just fine but I
can't make any of them to produce one single map. I've already tried
php/mapscript, mapserver's demo and MSAutoTest.
I might be facing the same problem all the time. I believe that MSAutoTest
is the must straightforward so here is the results I get with it:
root at scott gdal # ./run_test.py
version = MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
Processing: classtest1.map
ERN: Unable to access file. as. (classtest1.map) <br>
no result file generated, TEST FAILED.
Processing: class16_ndmap.map
ERN: Unable to access file. as. (class16_ndmap.map) <br>
Test done:
0 tested skipped
0 tests succeeded
39 tests failed
0 test results initialized
As a final act of despair I even chmoded my whole msautotest directory with
"chmod 0777 ./msautotest -R" but my tests kept consistently failing with the
same error messages.
What I am doing wrong? I welcome any suggestions as I'm really clueless what
else to try.
Thanks in advance for your attention,
Rodrigo Severo
