inline feature
Dirk-Jan Huisman
d.huisman at INGBCC.NL
Mon Mar 14 08:04:08 EST 2005
It still doesn't work. The inline feature disappeare after zooming.
This is the code.
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
20 20
END
TEXT '© 2005'
END
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 8
ANTIALIAS TRUE
COLOR 5 255 5
POSITION UR
FORCE TRUE
END
END
END
I'm using PHP/Mapscript and rosa-applet. Maybe i have to draw it through
the PHP-code? But how?
Dirk
-----Oorspronkelijk bericht-----
Van: Stephen Woodbridge [mailto:woodbri at SWOODBRIDGE.COM]
Verzonden: donderdag 10 maart 2005 15:50
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] inline feature
Dirk,
Just make sure that this is the last layer in your mapfile so when the
label cache is run it will be the first label draw. Then all the other
labels will avoid it. If it is not the first, and other labels are drawn
where it needs to be drawn, then it will get bumped and not draw. You
can also add FORCE TRUE to the label block.
-Steve W.
http://imaptools.com
Dirk-Jan Huisman wrote:
> Hi,
> My LAYER is:
> LAYER
> NAME "credits"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS
> 300 300
> END
> TEXT 'Hello world.'
> END
> CLASS
> LABEL
> TYPE BITMAP
> COLOR 0 0 0
> END
> END
> END
> The LAYER in the link below gives the same problem.
> best regards,
> Hi,
> did you try something like described in:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0103/msg00026.h
> tml
> Can you provide more info? The LAYER from your MAP file will help
> analyzing the problem.
> Best regards,
> Bart
>>Hi all,
>>I want to draw text (copyright) in my map. In my mapfile I put the
> code
>>(FEATURE keyword). The string is drawed once and it looks good. But
>>after zooming it's gone.
>>What to do to draw the text again after each request?
>>Dirk Jan
> Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
> Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
> E-mail post at ingbcc.nl
> Internet www.ingbcc.nl
> Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn
vertrouwelijk en alleen bedoeld voor het gebruik door de individu of
instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail
onterecht ontvangen heeft wilt u het ons dan laten weten.
> This e-mail and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they are
addressed. If you have received this e-mail in error please notify the
system manager.
Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn vertrouwelijk en alleen bedoeld voor het gebruik door de individu of instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail onterecht ontvangen heeft wilt u het ons dan laten weten.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the system manager.
