refresh
Ken Lord
kenlord at GMAIL.COM
Mon Mar 14 12:11:04 EST 2005
Hi Dirk,
I cant say that I've seen that problem, but I would like to add that
often for me the Rosa applet has another problem where one or more of
its buttons disappear from the map randomly. Sometimes clearing your
cache of java applets helps to fix it, but usually not for long.
And on a new windows xp sp2 machine the applet woouldn't load the
picture properly, the picture only being visible the insant you click
a tool on it.
This isn't the Rosa list, but perhaps other's here have some hints for us.
Cheers,
Ken Lord
Vancouver BC
On Mon, 14 Mar 2005 17:40:19 +0100, Dirk-Jan Huisman
<d.huisman at ingbcc.nl> wrote:
> Hi,
> I use the PHP/mapscript with the rosa applet. It works fine. But when i
> zoom the rectangle doesn't refresh. See the attached picture and you'll
> see what i mean.
> Is this problem caused by the applet? Is there a solution for this?
> Best regards,
> Dirk Jan
> Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
> Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
> E-mail post at ingbcc.nl
> Internet www.ingbcc.nl
> Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn vertrouwelijk en alleen bedoeld voor het gebruik door de individu of instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail onterecht ontvangen heeft wilt u het ons dan laten weten.
> This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the system manager.
