SDE on SQL Server
Bill TenBroeck
btenbroeck at ITSSG.COM
Tue Mar 15 05:43:25 PST 2005
Has anyone had any luck connecting using the "Single database Model" on SQL
Server. (Each DB stands alone and has its own service and port number.)
I have 2 servers set up, one using the "multiple database model" and can
connect to Mapserver successfully. Against the single database model server
I'm getting the following error:
msSDELayerOpen(): SDE error. SE_connection_create(): Invalid database name.
(-162)
I am using the following in the layer definition:
CONNECTIONTYPE SDE
CONNECTION "BILLP4,port:5155,sde,xxx,xxx"
DATA "BOUND_SDE.SDE.STATESP020,SHAPE"
On the DATA line I have tried every permutation I can think of; the example
shown is the way it shows up in ArcExplorer.
More information about the MapServer-users
