SDE on SQL Server
Howard Butler
hobu at IASTATE.EDU
Tue Mar 15 09:24:59 EST 2005
Bill,
I have confirmed by looking through the code that the "database"
argument *is* being passed into the connection creation function, so
I don't think that is the problem. Is the name of your "single
database model" database actually "sde"?
Is the client windows or unix (this shouldn't make much of a
difference)? Are there any complicating factors like FastCGI going
on here too?
Howard
>Has anyone had any luck connecting using the "Single database Model" on SQL
>Server. (Each DB stands alone and has its own service and port number.)
>I have 2 servers set up, one using the "multiple database model" and can
>connect to Mapserver successfully. Against the single database model server
>I'm getting the following error:
>msSDELayerOpen(): SDE error. SE_connection_create(): Invalid database name.
>(-162)
>I am using the following in the layer definition:
> CONNECTIONTYPE SDE
> CONNECTION "BILLP4,port:5155,sde,xxx,xxx"
> DATA "BOUND_SDE.SDE.STATESP020,SHAPE"
>On the DATA line I have tried every permutation I can think of; the example
>shown is the way it shows up in ArcExplorer.
