puzzling error message: arString(): Unable to access file.
adLabelString()
Rodrigo Severo
rodrigo.lists at FABRICADEIDEIAS.COM
Wed Mar 16 08:09:23 EST 2005
Bruce,
I faced exactly the same problem you are experiencing now. I used php
4.3.10 with the same results so it probably isn't a php issue.
The only "solution" I found was not to use php/mapscript at all. I could
get no answer from the list, neither when I reported my problem, nor
when I reported my "solution" of getting rid of php/mapscript to fix
mapserver.
As far as I can tell, if you enable php/mapscript in a Linux (maybe
Unix) environment, the whole mapserver suite gets broken/unusable.
I'm about to start building an application that will use mapserver and
it seems that I won't be able to use php/mapscript, sadly.
My advice: stay away from php/mapscript until someone with the
appropriate resources decide to look at/fix this issue. I already
offered my help to debug/test any changes and this offer is still valid,
obviously.
I hope this info is of some help to you,
Rodrigo Severo
Bruce Raup wrote:
>I have narrowed down my problem (described below). I repeatedly built
>MapServer, adding more features each time, and it worked until I added
>phpmapscript:
> --with-php=/usr/include/php \
> --with-php-regex-dir=/home/braup/Builds/php-4.3.4/regex
>It appears that the error messages in memory are not being handled
>properly, as each unsuccessful build, the details of the message
>changed. Now it is
> "sLoadMapString(): Unable to access file. on() "
>I think someone else recently wrote with a similar problem with php
>mapscript. If this isn't already a known bug, should I do something
>other than this message to report it? Are there any work-arounds?
Rodrigo Severo
Fábrica de Idéias
SBS -Ed. Empire Center Sala 1301 - Cobertura
Fone: (61) 321 1357
Fax: (61) 223 1712
Brasília/DF
When your only tool is a hammer,
all of your problems start looking like nails.
-- Mark Twain
