how to use java mapscript in tomcat4/jspenvironment?
Umberto Nicoletti
unicoletti at PROMETEO.IT
Wed Mar 16 11:55:39 EST 2005
There is no need to call System.loadLibrary as mapscript.jar should do
it for you in the initialization code (this one I am not sure, for sure
there is a patch for it in CVS).
Liangxu, please copy the mapscript.jar only in common/lib: this is not
windows!
Regards,
Umberto
On Wed, 2005-03-16 at 09:12 -0700, Ethan Alpert wrote:
> Look in your code for System.loadLibrary("mapscript")
> Clearly that's being called somewhere more than once.
> -e
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of wlx
> Sent: Wednesday, March 16, 2005 7:03 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] how to use java mapscript in
> Hi Umberto,
> I remove tomcat4.1, and install tomcat 5.5, and recomiled the
> mapserver with java mapscript, and copy the so file to /usr/lib/ and
> /usr/lib/jni/, copy the jar file to /usr/local/tomcat/common/lib/ and
> /usr/local/tomcat/shared/lib/, but there are something wrong too. You
> can see the error message here: http://210.77.68.214:8080/test.jsp.
> Best regard,
> Yours sincerely,
> Liangxu Wang
Umberto Nicoletti | We are Pentium of Borg.
+390415701366 unicoletti at prometeo.it | Division is futile.
Prometeo S.R.L. The Software Experience | You will be approximated.
