how to use java mapscript in tomcat4/jspenvironment?
    wlx
    wlx at MYGIS.ORG
    Thu Mar 17 17:41:20 PST 2005
 Thank you. I have resolved this problem with Umberto's solution.
> Look in your code for System.loadLibrary("mapscript")
> Clearly that's being called somewhere more than once.
> -e
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of wlx
> Sent: Wednesday, March 16, 2005 7:03 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] how to use java mapscript
> Hi Umberto,
>     I remove tomcat4.1, and install tomcat 5.5, and recomiled
> the mapserver with java mapscript, and copy the so file to
> /usr/lib/ and /usr/lib/jni/, copy the jar file to
> /usr/local/tomcat/common/lib/ and
> /usr/local/tomcat/shared/lib/, but there are something wrong
> too. You can see the error message here:
> http://210.77.68.214:8080/test.jsp.
>    Best regard,
>    Yours sincerely,
> Liangxu Wang
More information about the MapServer-users
