refresh
Dirk-Jan Huisman
d.huisman at INGBCC.NL
Thu Mar 17 01:48:52 PST 2005
Thanks!
It's simple. I didn't thought about that.
-----Oorspronkelijk bericht-----
Van: Constantin Cristian [mailto:constantin.a.cristian at GMAIL.COM]
Verzonden: woensdag 16 maart 2005 10:47
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] refresh
I had the same problem and the solution was simple, the problem apears
only
if you
have "TRANSPARENT TRUE" in the OUTPUTFORMAT in your map file set it to
FALSE
and it will work ok.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, March 15, 2005 5:32 PM
Subject: Re: [UMN_MAPSERVER-USERS] refresh
Le mardi 15 Mars 2005 16:13, Dirk-Jan Huisman a écrit :
> I use:
> browser IE 6.0
> OS windows 2000 professional.
> java virtual machine is what you get with the installation of windows
> 2000.
> Dirk
Rosa applet should work with IE on W2K, but with Sun java virtual
machine.
Can
you check which JVM IE is using ? You should find that somewhere in the
Advanced Options of IE. If you only have Microsoft's one, I think it
won't
work properly. You have to dl Sun's one from their site, and then tells
IE
to
use Sun JVM instead of Microsoft's.
(Or maybe it could work if you upgrade your Microsoft JVM, because I
think I
have understood they were trying to stick again to Sun compatibility ? ?
Maybe you should try with Firefox or Mozilla because I think they are
set to
use Sun JVM.
Blaise
Prins Mauritsstraat 17, Postbus 75, 4140 AB Leerdam
Telefoon (0345) 63 96 96, Fax (0345) 63 96 66,
E-mail post at ingbcc.nl
Internet www.ingbcc.nl
Deze e-mail en de eventuele bestanden die meegezonden zijn, zijn vertrouwelijk en alleen bedoeld voor het gebruik door de individu of instelling aan wie deze e-mail geadresseerd is. Als u deze e-mail onterecht ontvangen heeft wilt u het ons dan laten weten.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the system manager.
More information about the MapServer-users
