Tiger Shapefile tiling problem
Camden Daily
cdaily at GMAIL.COM
Thu Mar 17 12:17:49 EST 2005
You may need to install the devel packages for the underlying
libraries to compile against them. For example, you might have gd
installed, but maybe not gd-devel. The developer packages aren't
needed by RPMs, but they're usually necessary to compile software
against.
I've just taken to installing the devel packages for all the software
I install anymore...
-Camden
On Thu, 17 Mar 2005 12:09:42 -0500, Jeff Portwine <jdport at veritime.com> wrote:
> I tried doing the complile, but as expected it just blows up during the
> ./configure phase and I just can't get anywhere with it. I think mapserver
> is one of the most difficult to build programs i've dealt with. I never
> was able to get it to compile originally, and I was very happy when I found
> the debian package that I could install mapserver with.
> Now, I know that i have all the required packages installed because when I
> installed the debian package it updated all of the various libraries that
> mapserver requires. But when I try to do ./configure it can't find any
> of them. It looks to me like just about every library mapserver is
> complaining about is in /usr/lib but even when I try adding configure
> options like --with-gd=/usr or --with-gd=/usr/lib it still can't find the
> required libraries.... I just don't get it.
> libgd.so isn't hte only one it can't find... it can't find freetype, zlib,
> png, jpeg, or xpm either... here is a copy of the configure errors...
> configure: checking where FreeType 2.x is installed...
> checking for FT_Init_FreeType in -lfreetype... no
> freetype-config or libfreetype cannot be found, possibly needed for
> GD
> configure: checking where Zlib is installed...
> checking for zlibVersion in -lz... no
> Zlib (libz) library cannot be found, possibly needed for GD
> configure: checking where PNG is installed...
> checking for png_init_io in -lpng... no
> PNG (libpng) library cannot be found, possibly needed for GD
> configure: checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... no
> libjpeg not found. JPEG support not included, possibly needed for
> GD.
> configure: checking where libXpm is installed...
> checking for XpmFreeXpmImage in -lXpm... no
> XPM (libXpm) library cannot be found, possibly needed for GD
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... yes
> checking for libiconv_open in -liconv... no
> using libiconv from system libs.
> libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.12 or higher...
> checking for gdImageSetAntiAliased in -lgd... yes
> checking for gdImageSetAntiAliased in -lgd... (cached) yes
> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/local.
> Make sure GD 2.0.12 or higher is compiled before calling configure. You may
> also get this error if you didn't specify the appropriate location for one
> of GD's dependencies (freetype, libpng, libjpeg or libiconv).
> This is the output with no configure options... the only thing that changes
> if i put in things like --with-gd=/usr or --with-freetype=/usr, etc, is that
> it says it can't find things in /usr instead of being unable to find them in
> /usr/local.
> If anybody has any clues on how to get this working please let me know.
> All this headache just for one utility... :\
> -Jeff
