Tiger Shapefile tiling problem
Jeff Portwine
jdport at VERITIME.COM
Thu Mar 17 14:06:05 EST 2005
I'm not sure but i'm pretty sure I had to install gd-devel when I first
installed the rest of the mapserver debian package. At any rate, if i
try now to install the libgd2-dev package it says it has to uninstall
cgi-mapserver, libgd2-xpm, mapserver-bin, and php4-mapscript. After all
the trouble I had getting mapserver installed and working, i'm not about to
let anything uninstall them..
Is there a debian binaries package available anywhere ?
-Jeff
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, March 17, 2005 12:17 PM
Subject: Re: [UMN_MAPSERVER-USERS] Tiger Shapefile tiling problem
> You may need to install the devel packages for the underlying
> libraries to compile against them. For example, you might have gd
> installed, but maybe not gd-devel. The developer packages aren't
> needed by RPMs, but they're usually necessary to compile software
> against.
> I've just taken to installing the devel packages for all the software
> I install anymore...
> -Camden
> On Thu, 17 Mar 2005 12:09:42 -0500, Jeff Portwine <jdport at veritime.com>
> wrote:
>> I tried doing the complile, but as expected it just blows up during the
>> ./configure phase and I just can't get anywhere with it. I think
>> mapserver
>> is one of the most difficult to build programs i've dealt with. I never
>> was able to get it to compile originally, and I was very happy when I
>> found
>> the debian package that I could install mapserver with.
>> Now, I know that i have all the required packages installed because when
>> I
>> installed the debian package it updated all of the various libraries that
>> mapserver requires. But when I try to do ./configure it can't find
>> any
>> of them. It looks to me like just about every library mapserver is
>> complaining about is in /usr/lib but even when I try adding configure
>> options like --with-gd=/usr or --with-gd=/usr/lib it still can't find
>> the
>> required libraries.... I just don't get it.
>> libgd.so isn't hte only one it can't find... it can't find freetype,
>> zlib,
>> png, jpeg, or xpm either... here is a copy of the configure errors...
>> configure: checking where FreeType 2.x is installed...
>> checking for FT_Init_FreeType in -lfreetype... no
>> freetype-config or libfreetype cannot be found, possibly needed
>> for
>> GD
>> configure: checking where Zlib is installed...
>> checking for zlibVersion in -lz... no
>> Zlib (libz) library cannot be found, possibly needed for GD
>> configure: checking where PNG is installed...
>> checking for png_init_io in -lpng... no
>> PNG (libpng) library cannot be found, possibly needed for GD
>> configure: checking whether we should include JPEG support...
>> checking for jpeg_read_header in -ljpeg... no
>> libjpeg not found. JPEG support not included, possibly needed for
>> GD.
>> configure: checking where libXpm is installed...
>> checking for XpmFreeXpmImage in -lXpm... no
>> XPM (libXpm) library cannot be found, possibly needed for GD
>> configure: checking where libiconv is installed...
>> checking for iconv_open in -lc... yes
>> checking for libiconv_open in -liconv... no
>> using libiconv from system libs.
>> libiconv found. Enabling internationalization (-DUSE_ICONV)
>> configure: checking for GD 2.0.12 or higher...
>> checking for gdImageSetAntiAliased in -lgd... yes
>> checking for gdImageSetAntiAliased in -lgd... (cached) yes
>> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/local.
>> Make sure GD 2.0.12 or higher is compiled before calling configure. You
>> may
>> also get this error if you didn't specify the appropriate location for
>> one
>> of GD's dependencies (freetype, libpng, libjpeg or libiconv).
>> This is the output with no configure options... the only thing that
>> changes
>> if i put in things like --with-gd=/usr or --with-freetype=/usr, etc, is
>> that
>> it says it can't find things in /usr instead of being unable to find them
>> in
>> /usr/local.
>> If anybody has any clues on how to get this working please let me know.
>> All this headache just for one utility... :\
>> -Jeff
