upside down labels
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Mar 17 14:34:49 EST 2005
I have the same problem and have complained about it before. I have
reproduced it on 4.0.1 and 4.4.1.
LABEL
ANGLE AUTO
FONT "arial"
TYPE TRUETYPE
POSITION UC
SIZE 7
BUFFER 4
COLOR 0 0 0
OUTLINECOLOR 245 245 231
ANTIALIAS TRUE
PARTIALS FALSE
MINDISTANCE 250
MINFEATURESIZE 10
END
The problem is not that all labels are upside down, just random labels
are upside down. and a little bit of zooming will cause the labels to
reposition just slightly and then they will flip right-side up.
-Steve Woodbridge
Andy Canfield wrote:
> What does your label statement look like for that street layer?
> On Tue, 15 Mar 2005 10:45:08 -0800, Ryan, Adam <ARyan at co.linn.or.us> wrote:
>>Hey John,
>>I can't help you with the label problem, but I have a question if you've got
>>a minute.
>>I like your site. I see your adding little dot images with pop up
>>functionality client-side on top of your map. Did you compare this method
>>to rendering the points with mapserver and using an html image map element
>>and if so, would you mind sharing your findings?
>>Cheers,
>>Adam
>>>-----Original Message-----
>>>From: John Hagstrand [mailto:john.hagstrand at INTERAGERESEARCH.COM]
>>>Sent: Tuesday, March 15, 2005 10:15 AM
>>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>Subject: [UMN_MAPSERVER-USERS] upside down labels
>>>Hi,
>>>My street maps are displaying labels upside down. I see that
>>>bug 564 has already been entered for this.
>>>Here is an example on a live customer site. Of 48 labels, 5
>>>are upside down.
>>http://www.westportnow.com/realestate/map.php?
>>&irn=41.134325436851&irs=41.119548563149&ire=-73.309842191861&irw=-
>>73.324483808139&iract=zoomout&irsacct=10283
>>John
