About mapserver 4.4.1 and Chinese problem
Tinmean K. H. Liu
tinmean at YAHOO.COM.TW
Fri Mar 18 03:47:03 EST 2005
Thanks for your response.
The question is no solved.
I post the question on your discussion board.
About my question is about the "Label", I make a simple example
here: http://140.113.223.74/hc_river/test.php
Comparing the different mapfiles, the first one with labelitem
cannot be showed out.
Thank you, anyway.
--Tinmean K. H. Liu
> Hi,
> Have you set the fontset variable and copy the font to the right place
>if you are sured your code right?
> And if you can read chinese,welcome to
>http://www.cngis.org/bbs/forumdisplay.php?f=83 discuss the related topic.
> Liangxu Wang
>>Hi,
>> I installed mapserver 4.4.1 by using apt under Fedora Core 2.
>> From the "what's new" and mapfile reference, I use
>>"encoding" in my mapfile.
>> It looks like:
>>LAYER
>> NAME Hchc_river
>> TYPE LINE
>> STATUS ON
>> DATA Hchc_river
>> LabelItem "NAME"
>> #CLASSITEM "NO"
>> CLASS
>> NAME "Hchc_river"
>> COLOR 0 0 255
>> LABEL
>> COLOR 0 0 0
>> TYPE TRUETYPE
>> FONT moe_kai
>> SIZE 8
>> POSITION AUTO
>> PARTIALS FALSE
>> OUTLINECOLOR 255 255 255
>> ENCODING BIG5
>> END
>> END
>> TOLERANCE 5
>>END
>> And I have an example in my site:
>>http://140.113.223.74/hc_river/hello.phtml
>> The right code(BIG5), the right font, but failed.
>> Thanks for any response.
>>Tinmean K. H. Liu
