About mapserver 4.4.1 and Chinese problem
Steve Lehr
lehrs at ERAU.EDU
Fri Mar 18 08:04:00 EST 2005
I think the issue is the PHP
I have not had any success using mapserver 4.4.1 php code on Fedora -- not
sure if its still the regex issue. 4.2 works just fine. THere have been
some similar posts. I'd go back to 4.2, recompile php with the system regex
as noted when you do the configuration of mapserver ./configure --with-php
(sorry I don't have the options right here), but it tells you how to
recompile php.
I use 4.4 mapserver cgi, but 4.2 php they are compiled independently and
work just fine.
Steven Lehr
Assistant Professor
Freshmen Program
College of Engineering
Embry-Riddle Aeronautical University (LB159)
600 S. Clyde Morris Blvd.
Daytona Beach, FL 32114-3900
386-226-7740
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Tinmean K. H. Liu
Sent: Friday, March 18, 2005 3:47 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] About mapserver 4.4.1 and Chinese
problem
Thanks for your response.
The question is no solved.
I post the question on your discussion board.
About my question is about the "Label", I make a simple example
here: http://140.113.223.74/hc_river/test.php
Comparing the different mapfiles, the first one with labelitem
cannot be showed out.
Thank you, anyway.
--Tinmean K. H. Liu
> Hi,
> Have you set the fontset variable and copy the font to the right
place
>if you are sured your code right?
> And if you can read chinese,welcome to
>http://www.cngis.org/bbs/forumdisplay.php?f=83 discuss the related topic.
> Liangxu Wang
>>Hi,
>> I installed mapserver 4.4.1 by using apt under Fedora Core 2.
>> From the "what's new" and mapfile reference, I use
>>"encoding" in my mapfile.
>> It looks like:
>>LAYER
>> NAME Hchc_river
>> TYPE LINE
>> STATUS ON
>> DATA Hchc_river
>> LabelItem "NAME"
>> #CLASSITEM "NO"
>> CLASS
>> NAME "Hchc_river"
>> COLOR 0 0 255
>> LABEL
>> COLOR 0 0 0
>> TYPE TRUETYPE
>> FONT moe_kai
>> SIZE 8
>> POSITION AUTO
>> PARTIALS FALSE
>> OUTLINECOLOR 255 255 255
>> ENCODING BIG5
>> END
>> END
>> TOLERANCE 5
>>END
>> And I have an example in my site:
>>http://140.113.223.74/hc_river/hello.phtml
>> The right code(BIG5), the right font, but failed.
>> Thanks for any response.
>>Tinmean K. H. Liu
