About mapserver 4.4.1 and Chinese problem
Mario H. Basa
mhbasa at YAHOO.COM
Fri Mar 18 10:02:55 EST 2005
Hello,
I agree with Linagxu, it seems that you have forgotten
to create a fontset file. Here is what you should do:
1. create a file called fontset.lst in the same
directory as your map file.
2. add this to the fontset.lst (for fedora, check to
make sure that the path is correct)
bkai00mp /usr/share/fonts/zh_TW/TrueType/bkai00mp.ttf
3. add this to your map file:
FONTSET fontset.lst
Hope this works for you.
mario
yokohama, japan
--- "Tinmean K. H. Liu" <tinmean at YAHOO.COM.TW> wrote:
> Hi,
> Thanks for your response.
> The question is no solved.
> I post the question on your discussion board.
> About my question is about the "Label", I make
> a simple example
> here: http://140.113.223.74/hc_river/test.php
> Comparing the different mapfiles, the first one
> with labelitem
> cannot be showed out.
> Thank you, anyway.
> --Tinmean K. H. Liu
> > Hi,
> > Have you set the fontset variable and copy
> the font to the right place
> >if you are sured your code right?
> > And if you can read chinese,welcome to
> >http://www.cngis.org/bbs/forumdisplay.php?f=83
> discuss the related topic.
> > Liangxu Wang
> >>Hi,
> >> I installed mapserver 4.4.1 by using apt under
> Fedora Core 2.
> >> From the "what's new" and mapfile reference, I
> use
> >>"encoding" in my mapfile.
> >> It looks like:
> >>LAYER
> >> NAME Hchc_river
> >> TYPE LINE
> >> STATUS ON
> >> DATA Hchc_river
> >> LabelItem "NAME"
> >> #CLASSITEM "NO"
> >> CLASS
> >> NAME "Hchc_river"
> >> COLOR 0 0 255
> >> LABEL
> >> COLOR 0 0 0
> >> TYPE TRUETYPE
> >> FONT moe_kai
> >> SIZE 8
> >> POSITION AUTO
> >> PARTIALS FALSE
> >> OUTLINECOLOR 255 255 255
> >> ENCODING BIG5
> >> END
> >> END
> >> TOLERANCE 5
> >>END
> >> And I have an example in my site:
> >>http://140.113.223.74/hc_river/hello.phtml
> >> The right code(BIG5), the right font, but
> failed.
> >> Thanks for any response.
> >>Tinmean K. H. Liu
__________________________________
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
http://smallbusiness.yahoo.com/resources/
