About mapserver 4.4.1 and Chinese problem
Tinmean K. H. Liu
tinmean at YAHOO.COM.TW
Fri Mar 18 13:02:49 EST 2005
Basa and Wang,
Thank you very much.
I solve the problem (I am sorry for the silly mistake). And I
will apply it to my php-mapscript.
It should be modified . I hope it also works.
Thanks again.
--Tinmean K. H. Liu
>Hello,
>I agree with Linagxu, it seems that you have forgotten
>to create a fontset file. Here is what you should do:
>1. create a file called fontset.lst in the same
>directory as your map file.
>2. add this to the fontset.lst (for fedora, check to
>make sure that the path is correct)
>bkai00mp /usr/share/fonts/zh_TW/TrueType/bkai00mp.ttf
>3. add this to your map file:
>FONTSET fontset.lst
>Hope this works for you.
>mario
>yokohama, japan
>--- "Tinmean K. H. Liu" <tinmean at YAHOO.COM.TW> wrote:
>>Hi,
>> Thanks for your response.
>> The question is no solved.
>> I post the question on your discussion board.
>> About my question is about the "Label", I make
>>a simple example
>>here: http://140.113.223.74/hc_river/test.php
>> Comparing the different mapfiles, the first one
>>with labelitem
>>cannot be showed out.
>> Thank you, anyway.
>>--Tinmean K. H. Liu
>>>Hi,
>>> Have you set the fontset variable and copy
>>the font to the right place
>>>if you are sured your code right?
>>> And if you can read chinese,welcome to
>>>http://www.cngis.org/bbs/forumdisplay.php?f=83
>>discuss the related topic.
>>>Liangxu Wang
>>>>Hi,
>>>> I installed mapserver 4.4.1 by using apt under
>>Fedora Core 2.
>>>> From the "what's new" and mapfile reference, I
>>use
>>>>"encoding" in my mapfile.
>>>> It looks like:
>>>>LAYER
>>>> NAME Hchc_river
>>>> TYPE LINE
>>>> STATUS ON
>>>> DATA Hchc_river
>>>> LabelItem "NAME"
>>>> #CLASSITEM "NO"
>>>> CLASS
>>>> NAME "Hchc_river"
>>>> COLOR 0 0 255
>>>> LABEL
>>>> COLOR 0 0 0
>>>> TYPE TRUETYPE
>>>> FONT moe_kai
>>>> SIZE 8
>>>> POSITION AUTO
>>>> PARTIALS FALSE
>>>> OUTLINECOLOR 255 255 255
>>>> ENCODING BIG5
>>>> END
>>>> END
>>>> TOLERANCE 5
>>>>END
>>>> And I have an example in my site:
>>>>http://140.113.223.74/hc_river/hello.phtml
>>>> The right code(BIG5), the right font, but
>>failed.
>>>> Thanks for any response.
>>>>Tinmean K. H. Liu
>__________________________________
>Do you Yahoo!?
>Yahoo! Small Business - Try our new resources site!
>http://smallbusiness.yahoo.com/resources/
