crash on QueryByRect/QueryByAttr on Oracle Layer (mapserver
compiled by me)
Fernando S.
fsimon at UNIVALI.BR
Fri Mar 18 11:42:59 EST 2005
Hi Francesco,
If you used in your binaries the cvs version of maporaclespatial.c
or mapserver can be instable.
The problems about the three fields in data paramater I will check
the code to find the problem, I believe that can be a problem in the
core of the maporaclespatial.c. Can you send your data definition that
generate the error?
Thanks for your replay.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Francesco Sozzi wrote:
> Hi all,
> If I use precompiled binaries for Win32/Oracle I have no problem.
> If I try to compile myself everything still works properly (I can
> render, zoom, pan, querying, ecc...), but if I query (es.
> QueryByRect) Oracle Spatial layer, mapserver crashes.
> Another sympton: I have no problem if on DATA attribute I list only
> key and geometry fields. If I list some other fields, mapserver
> (compiled by me) crashes.
> There is something on how I compiled my binaries.
> Anybody has already experimented the same problem?...
> Bets regards
> Francesco
