crash on QueryByRect/QueryByAttr on Oracle Layer (mapserver
compiled by me)
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Mar 18 11:55:38 EST 2005
Hi Francesco,
> Another sympton: I have no problem if on DATA attribute I list only key
> and geometry fields. If I list some other fields, mapserver (compiled by
> me) crashes.
I had the same problem. When I recompiled with VC7.1 instead of VC6
everything worked fine. Which MSVC version are you using?
Best regards,
Bart
On Fri, 18 Mar 2005 16:28:41 +0100, Francesco Sozzi <fsozzi at INTERCAD.CH>
wrote:
> Hi all,
> If I use precompiled binaries for Win32/Oracle I have no problem.
> If I try to compile myself everything still works properly (I can
> render, zoom, pan, querying, ecc...), but if I query (es. QueryByRect)
> Oracle Spatial layer, mapserver crashes.
> me) crashes.
> There is something on how I compiled my binaries.
> Anybody has already experimented the same problem?...
> Bets regards
> Francesco
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
