tileindexed layer crashing...
Frank Warmerdam
fwarmerdam at GMAIL.COM
Sat Mar 19 09:42:14 EST 2005
On Fri, 18 Mar 2005 21:29:16 -0500, Mark Dieterich <mdieterich at gmail.com> wrote:
> So two seconds after I finished typing up this message, I wondered
> whether having the the NAME field and the TILEINDEX field within a LAYER
> have the same value was causing problems. It appears to be the problem.
> Once I renamed the NAME field, I got a map. Did I just miss this in
> the doc?
Mark,
For MapServer 4.4 I believe Steve added the ability for a layer
to use another specialized "tileindex" layer as it's tileindex instead
of just referring to an external file. I suspect he decides which case
applies by searching for a layer with the same name as the "tileindex"
argument which in your case recurses back to the same layer.
This would explain your problems.
I would suggest you file a bug report on this for Steve, with perhaps
the suggestion that:
o We not use SDE error for this particular error message.
o that the search for a tileindex layer should exclude the current layer.
o Perhaps something can be done to improve the error message to make
it clear a tileindex layer is being used.
I could be all wrong about what is going on of course.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
