Mapscript PHP Error - failed to map segment from shared object
Dylan Keon
dbkeon.ml at GMAIL.COM
Mon Mar 21 15:27:02 EST 2005
> On 03/21/2005 11:49 AM, Troy R. Johnson wrote:
>>From the command line things seem to work just fine. I can do the following:
>>/usr/local/bin/php phpinfo_mapscript.phtml > test.html
>>and test.html shows that the MapScript is loaded. Other test also seem to work from the command line.
>>>Yes, my PHP extensions is set to /usr/lib/php4
>>>which is where my php_mapscript.so has been copied to.
>>>I know it is trying to load the file and having problems, because
>>>if I remove the file php_mapscript.so I get a different error,
>>>it complains that the file doesn't exist.
>>>Any other ideas?
> Doh! I should have noticed you wrote that it works at the command line.
> You said you're using FC3. Do you have SELinux enabled? Make sure that
> isn't causing any weirdness...
> --Dylan
> On 03/21/2005 12:16 PM, Troy R. Johnson wrote:
> Thanks a bunch. It was a SELinux problem... I hadn't even thought about that.
> I'd forgotten that I even had it running, but that solved the problem.
> Thanks
> Troy
Tony,
Great, glad that worked. Please cc replies to the list too! Have fun...
--Dylan
