Mapscript PHP Error - failed to map segment from shared object
Dylan Keon
dbkeon.ml at GMAIL.COM
Mon Mar 21 15:05:29 EST 2005
On 03/21/2005 11:49 AM, Troy R. Johnson wrote:
>From the command line things seem to work just fine. I can do the following:
> /usr/local/bin/php phpinfo_mapscript.phtml > test.html
> and test.html shows that the MapScript is loaded. Other test also seem to work from the command line.
>> Yes, my PHP extensions is set to /usr/lib/php4
>> which is where my php_mapscript.so has been copied to.
>> I know it is trying to load the file and having problems, because
>> if I remove the file php_mapscript.so I get a different error,
>> it complains that the file doesn't exist.
>> Any other ideas?
Doh! I should have noticed you wrote that it works at the command line.
You said you're using FC3. Do you have SELinux enabled? Make sure that
isn't causing any weirdness...
--Dylan
