Problems reading a TIF file (newbie question)
Ray
ray at SUSTAINABLE.IE
Tue Mar 22 11:03:40 EST 2005
I am having problems displaying a TIF file using PHP mapscript, I suspect
that the problem lies in the map file.
gdalinfo PAGE48.TIF (name of the file) gives:
Driver: GTiff/GeoTIFF
Size is 4724, 6300
Coordinate System is `'
Metadata:
TIFFTAG_DOCUMENTNAME=JOB_NAME
TIFFTAG_IMAGEDESCRIPTION=DKB200:[OS50000.DUBGUIDE_4TH_MAPS]PAGE_CLIP_48.TIF;
TIFFTAG_SOFTWARE=Barco Graphics - V9.2
TIFFTAG_XRESOLUTION=600
TIFFTAG_YRESOLUTION=600
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 6300.0)
Upper Right ( 4724.0, 0.0)
Lower Right ( 4724.0, 6300.0)
Center ( 2362.0, 3150.0)
Band 1 Block=4724x8 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 255,255,255,255
1: 59,43,47,255
2: 0,137,159,255
<...cut...>
254: 255,255,255,255
255: 255,255,255,255
I used the TAB file to get the map EXTENT and projection:
$ cat Page48.TAB
!table
!version 300
!charset WindowsLatin1
Definition Table
File "./PAGE48.TIF"
Type "RASTER"
(318000,232000) (1,0) Label "Pt 1",
(321000,232000) (4723,0) Label "Pt 2",
(321000,228000) (4723,6296) Label "Pt 3",
(318000,228000) (1,6295) Label "Pt 4"
CoordSys Earth Projection 8, 42, "m", -8, 53.5, 1.000035, 200000, 250000
Units "m"
I also have a TFW file:
$ cat Page48.TFW
0.635324015247776
0
0
-0.635324015247776
317999.682337992
231999.682337992
My MAP file looks like this:
MAP
NAME PAGE48
STATUS ON
SIZE 472 630
IMAGETYPE PNG
EXTENT 318000 228000 321000 232000
UNITS METERS
FONTSET "./fonts/fonts.list"
SHAPEPATH "./data/"
IMAGECOLOR 15 158 120
PROJECTION
"proj=utm"
"ellps=mod_airy"
"lon_0=-8"
"lat_0=53.5"
END
WEB
IMAGEPATH "/var/www/html/mapscript/gmap-ms40/greenmap/test/"
IMAGEURL "/mapscript/gmap-ms40/greenmap/test/"
END
LAYER
DATA "./data/PAGE48.TIF"
TYPE RASTER
END
LAYER
NAME "test text"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
60 10
END
TEXT "This text should appear at the top of the image."
END
CLASS
LABEL
TYPE truetype
FONT arial
SIZE 12
POSITION CR
COLOR 0 0 0
END
END
END
END
And my code looks like this:
<?php
dl ("php_mapscript.so");
ms_ResetErrorList();
$map = ms_newMapObj ("greenmap.map");
$image = $map->draw();
$image_url = $image->saveWebImage(MS_PNG, 0, 0, -1);
$error = ms_GetErrorObj ();
print ("$error->code");
while ($error && $error->code != MS_NOERR)
printf ("Error in %s: %s<br>\n", $error->routine, $error->message);
$error = $error->next();
echo "<img src=$image_url width=$map->width height=$map->height>";
I get a nice green background with the text as I expected, but I'd really
like to see the map too...
Any ideas about what I'm doing wrong gratefully received.
Thanks,
Ray
