making efficient map layers
Jeff Portwine
jdport at VERITIME.COM
Thu Mar 24 10:06:47 EST 2005
When I use a class definition like this, I only get the 1 pixel line, I
don't see it overlayed on the wider line.
CLASS
maxscale 99000
STYLE
SYMBOL 0
SIZE 3
COLOR 0 255 0
END
STYLE
SYMBOL 0
SIZE 1
COLOR 255 255 255
END
END
This class only draws the white line and ignores the green style... I'm not
sure why.
-Jeff
>> - How do you go about changing the width of the different types of
>> roads? I assume each class of road is in a different layer and you
>> somehow manipulate the line width?
> In your class for the roads do something like this:
> CLASS
> EXPRESSION ...
> STYLE # first draw a 5 pixel wide green line
> SYMBOL 0 # built in circle symbol
> SIZE 5
> COLOR 0 255 0 # green
> END
> STYLE # then draw a 3 pixel wide white line on top of the green
> SYMBOL 0 # that leaves a 1 pixel border on each side of the white
> SIZE 3
> COLOR 255 255 255 # white
> END
> STYLE # then draw a 1 pixel wide black line down the center
> SYMBOL 0
> SIZE 1
> COLOR 0 0 0 # black
> END
> END
