Terraservice.Net DOQ data
Brian Fischer
bfischer at HOUSTONENGINEERINGINC.COM
Fri Mar 25 15:08:29 EST 2005
Robert,
I use the TerrServer imagery quite a bit and here is what my layer file
looks like. I will mention I had problems with using it with MapServer
4.4.1, so I ended up going back to 4.2.1 and it works fine. I never
figured out why it wouldn't work in the 4.4.1, but someone did post that
there is a bug with WMS client in that version. Also make sure you are
using a 24bit output image type, otherwise the images will not look that
great.
LAYER
NAME aerialphoto
METADATA
"wms_title" "USGS Digital Ortho-Quadrangles"
"wms_srs" "EPSG:26914" #NAD83 UTM zone 14N
LYRNAME "DOQs (orthophotos)"
LINK
"http://terraserver.microsoft.com/about.aspx?n=AboutTerraServiceOverview
END
STATUS OFF
TYPE RASTER
MINSCALE 1500
MAXSCALE 80000
CONNECTIONTYPE WMS
CONNECTION
"http://terraservice.net/ogcmap.ashx?VERSION=1.1.1&SERVICE=wms&LAYERS=DO
Q&FORMAT=png&styles="
END
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Robert Aldridge
Sent: Friday, March 25, 2005 1:52 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Terraservice.Net DOQ data
Greetings list...
I can never get anything but a blank image when trying
to incorporate terraservice.net DOQ imagery via WMS.
Could some kind soul look at my map file and give me
some hints? Or, better yet, could someone provide an
example of a working map file?
Thanks,
Robert
http://xxxxxxxx/cgi-bin/mapserv?map=/var/www/mapping/wms.map&mode=map
where wms.map is:
MAP
NAME "wms_test"
SIZE 800 500
STATUS ON
EXTENT -87.808037 33.865687 -87.673215 33.934717
UNITS METERS
IMAGETYPE PNG
WEB
IMAGEPATH /var/www/tmp
END
LAYER
NAME ortho
METADATA
"wms_srs" "EPSG:4326"
END
GROUP "BASE DATA"
STATUS DEFAULT
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION
Q&FORMAT=jpeg"
PROJECTION
"init=epsg:4326"
END
END
END
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
