coordinate systems transformations
Mauricio Leon
mleon at SCIENTIFICINFORMATICS.COM
Sun Mar 27 14:39:59 EST 2005
Thanks again Gregor,
I am trying to run your example code in php but I have the follwing error:
"Fatal error: [MapServer Error]: msProcessProjection(): major axis or
radius = 0 or not given in C:\ms4w\apps\et_map\htdocs\map_main.php on line
106"
where 106 is this:
$projInObj = ms_newprojectionobj("proj=latlong");
the error creating the projection object does not occur when the projection
info is give as an epsg code:
$projInObj = ms_newprojectionobj("init=epsg:26759");
does not yield error.
Any ideas?
