WFS bug? - multiple layers from same service
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Tue Mar 29 15:29:17 EST 2005
What's the mapfile look like? Is there a chance that there are name
colisions between the layers?
-e
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Godwin, Elizabeth
Sent: Tuesday, March 29, 2005 1:24 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers from
same service
I'm experiencing a wierd phenomenon with a mapfile i am working
with. It's a bit of a unique case in that the map is composed of 3
layers, all WFS layers coming from the same service.
The odd thing is...when I do this... only the FIRST layer in
the map is drawn, but using the class info from the LAST layer of this
service. If I draw the middle layer from a different service...the same
is true, except that middle layer draws normal. So FIRST is drawing
with THIRD styling, on top of SECOND that has it's own styling.
In this case, it's polygons, lines and points, so the polygons
are drawing with point symbology on top of lines. Or if all are coming
from the same service, all that is drawn is polygins with point
symbology. The last two layers are not drawn.
I'm working with a cvs version from a month ago or so, but I
also tested against 4.4.0
Shall I post a bug? I'm asking first in case I've overlooked
something silly.
Liz Godwin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050329/0b2625ad/attachment.html
