TRUETYPE Labels on Solaris
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Mar 30 07:48:40 EST 2005
Don Drake wrote:
> I've built everything from source.
> Just curious why you say PHP and mapserver need the same version of
> freetype when I run mapserver as a CGI? They're independent processes
> at that point.
Correct. I was thinking of PHP/mapscript in which case you are loading
both PHP and Mapserver into the same executable and they both have to
use the same shared libs.
-Steve
> Thanks.
> -Don
> On Tue, 29 Mar 2005 19:24:25 -0500, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>>Don,
>>You might check and make sure that you are using the same version of
>>freetype in BOTH PHP and mapserver otherwise there may be issues. You
>>might need to build both PHP and mapserver from source if you haven't.
>>Also make use that the version of freetype that you compiled against is
>>the version that you are actually loading at runtime. You might have a
>>different system version that is getting loaded.
>>-Steve W.
>>Don Drake wrote:
>>>Does anyone have TrueType labels working on Solaris? I am struggling
>>>to get these to work. Our application is being ported to Solaris and
>>>I've noticed that this simple layer will crash the PHP/Mapscript when
>>>I choose the TrueType Type in the map file.
>>>I also get no debugging output.
>>>The same layer works just fine on my Linux servers.
>>>Here's the layer:
>>> LAYER
>>> DEBUG ON
>>> NAME "credits"
>>> STATUS ON
>>> TRANSFORM FALSE
>>> TYPE ANNOTATION
>>> FEATURE
>>> POINTS
>>> 10 440
>>> END
>>> TEXT 'Copyright 2005'
>>> END
>>> CLASSPSERVER-USERS at lists.umn.edu
>>> LABEL
>>> POSITION CR
>>> COLOR 255 255 255
>>> PARTIALS FALSE
>>> FONT "arial"
>>> #TYPE BITMAP
>>> #SIZE small
>>> TYPE TRUETYPE
>>> SIZE 8
>>> BUFFER 4
>>> MINDISTANCE 300
>>> MINFEATURESIZE 10
>>> OUTLINECOLOR 37 62 130
>>> ANTIALIAS TRUE
>>> FORCE on
>>> END
>>> END
>>> END
>>>Any suggestions? I'm on Solaris 9, Mapserver 4.4.1, gd 2.0.33, freetype 2.1.9.
>>>If I change the type to bitmap, nothing crashes and I see maps.
>>>Thanks.
>>>-Don
>>>Donald Drake
>>>President
>>>Drake Consulting
>>>http://www.drakeconsult.com/
>>>http://www.MailLaunder.com/
>>>http://www.mobilemeridian.com/
>>>312-560-1574
