TRUETYPE Labels on Solaris
Don Drake
dondrake at GMAIL.COM
Wed Mar 30 00:03:36 EST 2005
I've built everything from source.
Just curious why you say PHP and mapserver need the same version of
freetype when I run mapserver as a CGI? They're independent processes
at that point.
Thanks.
-Don
On Tue, 29 Mar 2005 19:24:25 -0500, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Don,
> You might check and make sure that you are using the same version of
> freetype in BOTH PHP and mapserver otherwise there may be issues. You
> might need to build both PHP and mapserver from source if you haven't.
> Also make use that the version of freetype that you compiled against is
> the version that you are actually loading at runtime. You might have a
> different system version that is getting loaded.
> -Steve W.
> Don Drake wrote:
> > Does anyone have TrueType labels working on Solaris? I am struggling
> > to get these to work. Our application is being ported to Solaris and
> > I've noticed that this simple layer will crash the PHP/Mapscript when
> > I choose the TrueType Type in the map file.
> > I also get no debugging output.
> > The same layer works just fine on my Linux servers.
> > Here's the layer:
> > LAYER
> > DEBUG ON
> > NAME "credits"
> > STATUS ON
> > TRANSFORM FALSE
> > TYPE ANNOTATION
> > FEATURE
> > POINTS
> > 10 440
> > END
> > TEXT 'Copyright 2005'
> > END
> > CLASSPSERVER-USERS at lists.umn.edu
> > LABEL
> > POSITION CR
> > COLOR 255 255 255
> > PARTIALS FALSE
> > FONT "arial"
> > #TYPE BITMAP
> > #SIZE small
> > TYPE TRUETYPE
> > SIZE 8
> > BUFFER 4
> > MINDISTANCE 300
> > MINFEATURESIZE 10
> > OUTLINECOLOR 37 62 130
> > ANTIALIAS TRUE
> > FORCE on
> > END
> > END
> > END
> > Any suggestions? I'm on Solaris 9, Mapserver 4.4.1, gd 2.0.33, freetype 2.1.9.
> > If I change the type to bitmap, nothing crashes and I see maps.
> > Thanks.
> > -Don
> > Donald Drake
> > President
> > Drake Consulting
> > http://www.drakeconsult.com/
> > http://www.MailLaunder.com/
> > http://www.mobilemeridian.com/
> > 312-560-1574
Donald Drake
President
Drake Consulting
312-560-1574
