ogrinfo show x y columns as strings
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri May 6 15:55:45 EDT 2005
On 5/6/05, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> duh, I think I tried all combinations now :-0
> all info I could google or find was about ODBC vrt's. IF it's possible
> maybe it's an idea to put a vrt and csv file in the helpfile of
> http://www.gdal.org/ogr/drv_vrt.html as an non odbc example?
Richard,
Try:
<OGRVRTDataSource>
<OGRVRTLayer name="testpoints">
<SrcDataSource relativeToVRT="1">testpoints.csv</SrcDataSource>
<SrcLayer>testpoints</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>epsg:28992</LayerSRS>
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
I generally avoid using the directory name for the datasource as it will
only be recognised as a csv datasource if at least half the files in it
are .csv files. The above worked fine for me:
Had to open data source read-only.
INFO: Open of `richards.ovr'
using driver `VRT' successful.
Layer name: testpoints
Geometry: Point
Feature Count: 2
Extent: (100000.000000, 400000.000000) - (110000.000000, 411000.000000)
Layer SRS WKT:
PROJCS["Amersfoort / RD New",
GEOGCS["Amersfoort",
DATUM["Amersfoort",
SPHEROID["Bessel 1841",6377397.155,299.1528128,
AUTHORITY["EPSG","7004"]],
AUTHORITY["EPSG","6289"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4289"]],
PROJECTION["Oblique_Stereographic"],
PARAMETER["latitude_of_origin",52.15616055555555],
PARAMETER["central_meridian",5.38763888888889],
PARAMETER["scale_factor",0.9999079],
PARAMETER["false_easting",155000],
PARAMETER["false_northing",463000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","28992"]]
text: String (0.0)
x: String (0.0)
y: String (0.0)
OGRFeature(testpoints):1
text (String) = test
x (String) = 100000
y (String) = 400000
POINT (100000 400000)
OGRFeature(testpoints):2
text (String) = test2
x (String) = 110000
y (String) = 411000
POINT (110000 411000)
PS. I have updated the drv_vrt.html to mention that datasources other
than odbc are supported. I didn't add any extra examples though.
Best regards,
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
