How to enable SLD in Mapserver?
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon May 9 15:11:34 EDT 2005
When you do a ./mapserv -v, what is your output?
..Tom
> -----Original Message-----
> From: Bobby Fung [mailto:bobbyfung at hotmail.com]
> Sent: Monday, 09 May, 2005 15:05
> To: Bobby Fung; Kralidis,Tom [Burlington];
> MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] How to enable SLD in Mapserver?
> This is the url with sld parameter:
> http://192.168.3.102/cgi-bin/mapserv?map=/var/www/html/mapserv
> er/service/config.map&version=1.1.1&service=WMS&request=GetMap
> &srs=EPSG:4326&bbox=-180,-90,180,90&format=image/png&layers=la
> nd_shallow_topo_2048,rivers&styles=,&transparent=true&width=50
> 0&height=300&sld=http://192.168.3.102/mapserver/sld/rivers.sld
> And this is the url without sld:
> 0&height=300
> I got exactly a same image from these two url....
> ----- Original Message -----
> From: "Bobby Fung" <bobbyfung at hotmail.com>
> To: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>;
> <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, May 09, 2005 4:01 PM
> > The problem is that the map I got from mapserver throught WMS looks
> > the
> > same
> > as I didn't included the SLD parameter. And I am sure that
> the SLD script
> > and the mapfile is correct since I took them directly from
> "MapServer OGC
> > Web Services Workshop".
> > I have attached the mapfile and sld file to this email anyway.
> > Thanks!
> > From: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>
> > To: "Libo Feng" <bobbyfung at HOTMAIL.COM>;
> > Sent: Monday, May 09, 2005 3:45 PM
> > Subject: RE: [UMN_MAPSERVER-USERS] How to enable SLD in Mapserver?
> >> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> >> On Behalf Of Libo Feng
> >> Sent: Monday, 09 May, 2005 14:37
> >> To: MAPSERVER-USERS at LISTS.UMN.EDU
> >> Subject: [UMN_MAPSERVER-USERS] How to enable SLD in Mapserver?
> >> Hello,
> >> I tried to enalbe SLD on my Mapserver but I can't make it
> work. The
> >> following is the parameters that I used to configure the Makefile:
> >> ./configure --without-tiff --without-eppl --with-threads
> --with-proj
> >> --with-gdal=/usr/local/bin/gdal-config --with-ogr
> >> --with-gd=/usr/local --with-freetype=/usr/bin --with-ming
> >> --with-wmsclient --with-wfs --with-wfsclient
> >> The mapserv CGI works all right but it just won't take my
> SLD script.
> >> I tested with the mapfile, sld scipt and shape files from the
> >> "MapServer OGC Web Services Workshop"
> >> (http://devgeo.cciw.ca/ms_ogc_workshop/index.html)
> >> and it doesn't work either. So I think it's my CGI's problem. Am I
> >> missing anything?
> > What sort of problems are you running into? How is it not
> taking your
> > SLD?
> > ..Tom
> >> I appreciate any help! Thanks.
